Does Vray 5 work with C4D Team Render at all? It's super convenient for certain things. Thanks!!
Vray 5 with Team Render
3D Scenes, Shaders and Courses for V-ray and Corona
NEW V-Ray 5 Metal Shader Bundle (C4D/Max): https://www.3dtutorialandbeyond.com/...ders-cinema4d/
@3drenderandbeyond on social media @3DRnB Twitter
Thanks Deyan!3D Scenes, Shaders and Courses for V-ray and Corona
Hi Oliver,
you still have the standalone and other systems for that. TeamRender is nice for animation (and “free” if that matter) and I still like to have that option so I’ll be happy if they will add that in the future(I guess is only a matter of time).
That being said performance is bad in my experience, when rendering animations with Corona using TeamRender I loose almost 50% of my PC nodes performance, so regardless if you use Vray or not you may still want to look for alternatives if you want to get the best out of your hardware3D Scenes, Shaders and Courses for V-ray and Corona
Hey oliver_kirstein ,
as Alex Kasabov stated above it is in our to do list to add support for Team Render. There are some things that we need to do before we start adding it. It's not as simple as just start working on it but we need to do some preparations as well. There are a lot of things that we need to take in to consideration before start working on it. Take Chaos Cosmos as a simple example. We need to make sure that Team Render understands those assets and their location on the disk to make sure they're transferred correctly. It wouldn't make much sense and wouldn't be optimal if we added support for Team Render then introduce Chaos Cosmos and then start working on team render again because we need to add support for Cosmos there.
DR did not work for single images because of the long preparation time before the rendering starts ....
Thank you!Last edited by shaio; 09-12-2021, 04:31 AM.Ivan Shaykov
chaos.com
Deadline allows rendering with both Cinema 4D Command line and V-Ray Standalone. If you use V-Ray Standalone for Deadline you will need a V-Ray Render Node license only but if you use the Cinema 4D CommandLine then you'll need to have both CommandLine and V-Ray node licenses sine CommandLine renders with V-Ray and both licenses are engaged.Ivan Shaykov
chaos.com
