Texture Flip
  • Texture Flip
    Hi Guy´s,
    my next question.
    My cam is inside a cylinder and I need a way to flip the texture so I can see my texture correctly.
    I can't find a option to flip the texture.
    I tried the C4D > Layer > Effect > Horizontal Flip but it don't work and I can't find a V-Ray option to flip the texture.
    Some ideas?
    Thanx
    Hello Rickmc ,
    You can flip the texture by simply making the value of the length a negative number in the material tag properties.
    I hope this is of help.
    Aleksandar Kasabov
    chaos.com
      Originally posted by Rickmc View Post
      Hi Guy´s,
      my next question.
      Some ideas?
      Thanx
      You can do like Aleksandar suggested, if for whatever reason you need that at a shader level you can load the texture using a Vraybitmap, set the mapping placement in crop mode and switch the width to -1.
      3D Scenes, Shaders and Courses for V-ray and Corona
      NEW V-Ray 5 Metal Shader Bundle (C4D/Max): https://www.3dtutorialandbeyond.com/...ders-cinema4d/
      @3drenderandbeyond on social media @3DRnB Twitter
        Is the projector shader also fully supported by Vray? Or is this baked?
          Thanx, it worked.
          I´ll would never imagine this way by myself.
            The Projector and all the effect shaders are not supported for baking. Because of their nature and how they are calculated baking them would not give the expected result. Most of them will have to be implemented natively. You can check what is supported, baked or unsupported in our documentation page with the Supported features in V-Ray 5.
            Ivan Shaykov
            chaos.com
