Get noisy image when using Vray light texture
  • Get noisy image when using Vray light texture
    I'm using a Vray Dome Light in a scene and I've added a HDRI image to the Texture tab of the Light (Dome Tex). The result is a very noisy image, as you can see. This is happening with C4D R23 and V-Ray 5. I've never experienced this with earlier versions of V-Ray. Any idea why?
    Hello it_refplus ,
    Could you please share a test scene where the issue is reproducible with all assets for it so we can have a look? Also, please share more details about your setup (exact Cinema4D and V-Ray versions, OS, are you using V-Ray CPU or V-Ray GPU). If using V-Ray GPU, please let us know what is your GPU and GPU driver.
    It would also be helpful if you can share which earlier versions of V-Ray didn't produce the issue.
    Aleksandar Kasabov
    chaos.com
      I finally solved the problem. It seems that by adding an image to the light texture, it darkened the image and I had to increase the light intensity, which created all that noise. I simply adjusted the camera sensitivity instead, and it worked very well. Thanks.
        Hello it_refplus ,
        I am glad to hear that you resolved the issue. Should you have further queries, please don't hesitate to let us know here or via our contact form here.
        Aleksandar Kasabov
        chaos.com
          interesting!! I'll have to keep that in mind!
