How can I control the location/orientation of the light texture (lightdome)?
  • How can I control the location/orientation of the light texture (lightdome)?
    How can I control the location/orientation of the light texture (lightdome)? Controls seem to be missing from V5.
    Just rotate the light.
      That's what I did, but I have no visual reference so it's trial & error process. Thanks.
        Hello it_refplus,
        You can start the Interactive render and you will see the rotation of your dome light as you adjust it. I hope this is of help.
        Aleksandar Kasabov
        chaos.com
          it is very simple.The x-axis indicates the direction of light in HDRI.
            Originally posted by aleksandar.kasabov View Post
            Hello it_refplus,
            A more efficient way would be to be able to see HDR in a viewport. Interactive render is not responsive enough for now.
              If you need a visible object in your scene, I'd just setup a quick xpresso (see the attached image) and just save that as a preset and reuse it. The texture slot of the dome drives the luma tex slot of the material.
              You could even transfer it in python and assign a shortcut/icon for it.
                Here is a quick project file with that setup and some additional UI/HUDs
                  I tested your dome version. Is good. Thank you, it will make my job easier.
                  Only why it is not implement to VRAY by default?
                    Thanks sirio76 for pointing out a mirroring issue (only in the viewport). Now that's fixed and I have also added a couple of other nifty controls.
                    Adding also a few screenshots and a short screen rec of the setup
                    Click image for larger version  Name:	Cinema_4D_xfABuKnWBA.png Views:	8 Size:	95.5 KB ID:	1127469Click image for larger version  Name:	Cinema_4D_e82glTiGjz.png Views:	6 Size:	787.8 KB ID:	1127470
                      Wow! thanks a lot for the update Yunal
                      3D Scenes, Shaders and Courses for V-ray and Corona
                      NEW V-Ray 5 Metal Shader Bundle (C4D/Max): https://www.3dtutorialandbeyond.com/...ders-cinema4d/
                      @3drenderandbeyond on social media @3DRnB Twitter
