Hi, the polygonselection doesn't work at my S24 Vray 5...
Polygonselection
Hi HarrySeidl, can you check the V-Ray console for warnings or errors (Extensions -> Console -> V-Ray or Shift + F10)?
I suspect that the problem in your case is that a single material is used multiple times on the same object - this is not currently supported, regardless if there is a polygon selection for one of the material assignment.
Hi deyan.hadzhiev - perfect - it is solved - new (copy of the original) material! Thanks!!!!!
1 Photo
