Vfb
  • Vfb
    Hello
    Does anyone of you have the same problem I have an AMD 5950 when starting the VFB everything works normally but if I stop the Renderer about 3 times and restart the VFB freezes?
    Had an I7 Intel before, I had no problems, everything worked normally!
    Thank-you!
    Hello Wohnraumdesign,
    Could you share with us a recording of your screen where this can be seen? Also, please share more information about your system (OS, RAM, Cinema4D and V-Ray versions, etc).
    Thank you.
    Aleksandar Kasabov
    chaos.com
      Hello
      I installed the latest studio driver from Nvidia 466.63 and the problem has apparently been resolved. If not, I will send you the video and the data.
      Thank-you!
        I am glad to hear that you managed to resolve the issue. Should it happens again, please let us know.
        Aleksandar Kasabov
        chaos.com
          Hi Aleksandar, do you recommend the nvidia Studio- or the Game Driver. I have two 2080 Ti with bridge running.
            Hello haniel1107,
            The recommended NVIDIA driver for V-Ray GPU is version 466.47. You can check the current recommended driver version here.
            Aleksandar Kasabov
            chaos.com
              Hello haniel1107,
              Thank you..
              Also for interactive use only? For rendering I am still stuck to CPU rendering... less problems
                It is important to note that V-Ray and V-Ray GPU are two different render engines and not everything supported on V-Ray is also supported on V-Ray GPU. You can find a list of the supported features on both V-Ray and V-Ray GPU here.
                Aleksandar Kasabov
                chaos.com
                  Thank you!
                    Yes, thank you, I know..
                    Just liked to know what is official recommended for IPR..
                      The driver version, displayed on our website is recommended both for Production and Interactive rendering when using V-Ray GPU.
                      Aleksandar Kasabov
                      chaos.com
                        Thank you!
