MultiSubTex shader
  • MultiSubTex shader
    Hey guys/ shaio
    just note that a new version of V-ray came out today... great new features and i can't wait to test them... one thing that i've notice is that the MultiSubTex material is not working or i don't get
    the only way it works is with "render ID" and "scene name"
    on this texture can we ask to add a random by position; rotation; scale and polygon? Imagine to have a wall with several cuts in a single object and the variation be by polygon....
    thanks in advance
    best
    ​​​​​​​nuno
    Hello nunomatos,
    I apologize for the delayed reply. Could you please share more information about the issues that you experience with the MultiSubTex? Sharing a test scene where those issues are visible would be helpful. You can also check our documentation page about the VRayMultiSubTex shader here.
    We will be working on improving the MultiSubTex shader but this will take some time and your patience and understanding will be very appreciated. Thanks.
    Aleksandar Kasabov
    chaos.com
      Hi Aleksandar
      in this last update, i guess is working now need to test more.
      about our request is having a possibility of doing this
      at least having the possibility of using the variation shader from C4D...
      the big advantage is that we can use ONLY a single texture (wood for example) and random the position to avoid visual repetitions, saving memory and time to push the textures...and save us time to add position variations manually
      hope it makes sense... this is already implement in your other products V-ray max (VRayUVWRandomizer) here for example or corona for c4d
      Video - https://www.dropbox.com/t/qw37rnWxxENb8wTg
      thanks in advance
      nuno
        Hello,
        Thanks for those details.
        VrayUVWRandomizer is on our to-do list and will be added in the future. We are also researching how to add support for the C4D variation shader. shaio explained in more details about those features here.
        I hope this is of help.
        Aleksandar Kasabov
        chaos.com
