warning: Failed to init Texture RGB Color Space conversion from lin_adobergb to lin_srgb
  • warning: Failed to init Texture RGB Color Space conversion from lin_adobergb to lin_srgb
    When I render with Distributed Rendering this message comes up. warning: Failed to init Texture RGB Color Space conversion from lin_adobergb to lin_srgb
    What can I do to fix it and where ?
    THX for Help
    Have the same also without DR.. would like to know, too..
      Hello,
      This warning appears when the texture you are using is in adobergb color space and the color profile of the bitmap shader is set to “embedded”. Switching the color profile of the texture to sRGB prevents the warning from appearing.
      Aleksandar Kasabov
      chaos.com
        How can i find out, which one produce this error? Open an old scene with tons of textures
        I got this Warning:
        [21:49:34.638] Warning : Failed to init Texture RGB Color Space conversion from scene-linear Rec.709-sRGB to acescg
        How can i fix this?
        Software:
        3ds max 2014 / ACESCG Environment / latest V-Ray GPU
          Hello TIWO Design,
          For queries, regarding V-Ray for 3ds Max, please open a thread in the V-Ray for 3ds Max section of the forum. Thank you.
          Aleksandar Kasabov
          chaos.com
            Hiya, sorry to add another thread hijack, but this is the only mention of this error via quick googling.
            First this doesn't seem to break in C4D w/ R2024.4 and V-Ray 6.20.02 since things are nicely linked!
            Second, this can happen in Maya too. Even if your OCIO envar sets things to ACEScg/ACES 1.0 SDR-Video, V-Ray can get a hard override out of ACEScg into scene-linear rec.709/sRGB. If that happens, Maya thinks you are rendering ACEScg whereas V-Ray is not actually so things are jumbled and all your colors look wrong. This is because you are rendering in scene-linear rec.709/sRGB but displaying it in ACEScg. It lives here in the Maya globals:
ID:	1217027Click image for larger version
