Get Transparent Alpha in Blend Material
  • Get Transparent Alpha in Blend Material
    Hi! So I want to add water drops on top of a texture. I have made my base material and then another material with the Alpha Channel and a png. of the image.
    However, It keeps rendering the color of the diffuse channel. Any ideas where I am going wrong?
    Hello jami_stewart,
    You could achieve the desired effect by using a V-Ray Material and add your water drops texture as a Coat in the Coat amount slot. You could add it in the bump channel as well. Please check my example setup below.
    I hope this is of help.
    Aleksandar Kasabov
    chaos.com
      Originally posted by aleksandar.kasabov View Post
      Hello jami_stewart,
      Brilliant! Thank you!!!
