Bitmap rotation and mapping controls
  • Bitmap rotation and mapping controls
    Hello,
    I want to rotate my bitmap 90 degrees, how can I do that in Vray C4D?
    Click image for larger version  Name:	Screenshot_93.jpg Views:	0 Size:	370.8 KB ID:	1121675
    I use nodal shading in C4D S24,
    Something like this in Vray for Maya,
    Click image for larger version  Name:	Screenshot_92.jpg Views:	0 Size:	64.4 KB ID:	1121676
    Same question on mapping type for an HDRI, in Vray's DomeLight. Are there controls for flipping the map horizontally for example or for horizontal rotation
    How do you do that in Vray C4D?
    Click image for larger version  Name:	Screenshot_95.jpg Views:	0 Size:	67.7 KB ID:	1121677
    Best,
    Muhammed
    Muhammed Hamed
    V-Ray GPU product specialist
    chaos.com
    I’m afraid you can’t do that right now (I haven’t checked on latest build though). Normally you can do that by using the transform tool inside the C4D layer shader but last time I check it wasn’t working.
    AFAIK your only options are to rotate the UV inside Cinema or the bitmap using PS.
    3D Scenes, Shaders and Courses for V-ray and Corona
    NEW V-Ray 5 Metal Shader Bundle (C4D/Max): https://www.3dtutorialandbeyond.com/...ders-cinema4d/
    @3drenderandbeyond on social media @3DRnB Twitter
      Thanks Sirio76,
      I'm on the latest stable build, rotating the UVs or the bitmap itself outside of Cinema are no options for me. I think I will wait
      Muhammed Hamed
      chaos.com
        Maybe you can use the transform inside the layer and bake the results using the Vray baking shader. In past this worked for me for other unsupported shaders, you should give it a try
          Thanks! will give this a try
          Muhammed Hamed
          chaos.com
