Hi all, I am new to this field with GPU`s, I have the feeling my graphics card does not need the full power to render as evident in the picture I think times. Because in utilization it says 2-max 6%. Because with CPU it jumps directly to 100%. Can you set this somewhere? And where? would be very nice if you can send me some screenshot where I can adjust it. Thanks a lot
GPU rendering help
Hello alex_obrist,
Please note that with the task manager there are many parameters that can be monitored and it won't show you the correct GPU utilization. You can use a third-party tool, such as GPU-Z to monitor the GPU load. I hope this is of help.Aleksandar Kasabov
chaos.com
Hey alex_obrist ,
Depending on the Graphics card and driver you should a "Compute" or "CUDA" mode available for you to select and monitor your GPU usage while rendering instead of the currently selected ones "3D, Copy, Video Encode or Video Decode".
Here is a quick screenshot and how it looks:
Ivan Shaykov
chaos.com
