When use linear image?
  • When use linear image?
    Hi, now that I have free time I am trying to understand some aspects of Vray that I do not understand. In this case it is the issue of when to use images in linear mode. I have been reading, studying the Cosmos Vray materials and watching some tutorials and I have some doubts on the subject.
    Perhaps it is a beginner's question and the answer is excessively complicated but I want to try to understand how to use the maps.
    I don't mean the normal maps which are always in linear mode
    METAL / ROUGHNESS
    Normally coming from programs like Substance they would always be in linear mode except Albedo which would be in sRGB. But:
    · Is it necessary to set Albedo to sRGB or is it better to use “Default”?
    · If we have an AO map to use with Vraylayer in the Difusse, do I have to use it in Linear mode (like the rest of the maps in Metal / Roughness), do I have to use "Default" or set sRGB? Can I mix the albedo (non-linear) with a linear AO?
    SPECULAR / GLOSSINESS
    Looking at the dielectric materials of Cosmos, it always uses the same system:
    Diffusse: sRGB
    Specular: sRGB
    Glosiness: Linear
    · Is this the correct system?
    · Do I need to set sRGB mode or is it better to use "Default"?
    · Its better use Linear mode even in Specular/Glossiness in every slot?
    · If I have a displacement map in Specular / Glossines do I need to set it to linear mode?
    Thanks in advance for your time and effort.
    as far i know the new vray 5 handles all that for you internally, so in that case keep all default.
      Ok, Thanks Stefan!
        Last time I check normal maps still needed to be set in linear mode.
        3D Scenes, Shaders and Courses for V-ray and Corona
        NEW V-Ray 5 Metal Shader Bundle (C4D/Max): https://www.3dtutorialandbeyond.com/...ders-cinema4d/
        @3drenderandbeyond on social media @3DRnB Twitter
