Vray Bitmap
  • Vray Bitmap
    Hi...a question....
    is it still necessary to put every bitmap in the vray bitmap or does it work without? For example in the 2 sided material?
    Is not necessary, you can use the standard C4D loader
    3D Scenes, Shaders and Courses for V-ray and Corona
    NEW V-Ray 5 Metal Shader Bundle (C4D/Max): https://www.3dtutorialandbeyond.com/...ders-cinema4d/
    @3drenderandbeyond on social media @3DRnB Twitter
      "is it still necessary to put every bitmap in the vray bitmap"
      just for the record, it was also not necessary in the past (only more efficient for DR as no internal conversion was needed then)
        Hello rohdan,
        As sirio76 mentioned above, you can use the standard C4D loader for loading your textures. You can also check this page for more information on the support for other native C4D shaders.
        Aleksandar Kasabov
        chaos.com
