Cosmos not working
  • Cosmos not working
    Every time I try to export anything from cosmos in C4D, it gives me this error. It has only started happening recently...what is going on?
    Hello howelaw,
    Are you trying to import the asset via the Cosmos browser inside Cinema4D or through your browser (visiting http://localhost:30305/)? Also, please specify the exact versions of V-Ray, Cinema4D, and the Cosmos browser (go to ...> About). Do you experience this issue with any assets or only selected ones? Thank you.
    Aleksandar Kasabov
    chaos.com
      I have the same problem import the asset via the Cosmos browser inside Cinema4D or through the browser.
        Originally posted by aleksandar.kasabov View Post
        Hello howelaw,
        Browser inside Cinema4D,
        Cinema4D R23.11
        Vray 5, update 2.5 (the latest one)
        Chaos Cosmos • Build: 2022.06.21-267456
        Also gives me this error when I first open the Cosmos browser
          Hello,
          This seems to be a bug and I have already reported it (bug ID: GALAXY-2405) to our developers for fixing. I will let you know once we have updates on the matter. Thank you.
          Aleksandar Kasabov
          chaos.com
            Hello,
            Please note that this issue was recently fixed and you shouldn't see any unsupported assets in the Cosmos browser.
            Please let me know if you need further assistance.
            Aleksandar Kasabov
            chaos.com
              aleksandar.kasabov In my browser i have this message and I have more materials then via the Cosmos browser inside Cinema4D.
                Hello craveiro,
                It is expected to see more assets when you access the Cosmos browser via your Internet browser as you will then be able to see all available assets. When you access the browser inside Cinema4D you will only see the assets, compatible with V-Ray for Cinema4D. I hope this makes sense.
                Aleksandar Kasabov
                chaos.com
                  Hello craveiro,
                  Hello aleksandar.kasabov I thought it would be available for all platforms, in which case I hope you add more materials for V-Ray Cinema4D as they are very useful, thank you.
                    Hello craveiro,
                    We are working on constantly expanding our asset library and we will be adding more materials in the future. However, some assets are optimized for specific platforms/ V-Ray versions, and in those cases the assets won't be visible everywhere. I hope this is of help.
                    Aleksandar Kasabov
                    chaos.com
                      The Cosmos Browser don't work anymore since the last two updates.
                      I can open it but can't do anything.
                      It seams to be freezed.
                      My specification: C4D R21 / Mac OS 11.6.7
                        Hello, in my C4D R21 / Win 10 is ok
                          If I click anything nothing happens
                            Hello Rickmc,
                            Could you please open a support ticket about this issue via our contact form? Please describe the issue and send us the cb.log file, which should be located here:
                            Code:
                            /Library/ChaosGroup/ChaosCosmos
                            Aleksandar Kasabov
                            chaos.com
                            • #15
                              @aleksandar.kasabov Done, thank you
