Displacement height wit Motion Blur
  • Displacement height wit Motion Blur
    Hello,
    just like to ask, if this is a normal behaviour or am I doing something wrong.
    Recognised it randomly..
    The displacement height (shift) seems different with motion blur.. is this correct?
    Thanks!
Name:	Screenshot 2022-07-11 11.34.06.jpg
    Hey, Hani,
    It is normal if the comera is moving (e.g., following the car path). You can control it if you don't need it. (artificially motion blur within object properties).
    Cheers,
    Boyan Nalchadjiiski | QA Engineer @ Chaos |
    E-mail: boyan.nalchadjiiski@chaos.com
      hello boyan ,
      thanks, good to know... !!
      I will play around with it..!
        Originally posted by boyan View Post
        Hey, Hani,
        Cheers,
        Sorry to come back... I guess I am blind. but, where can I set "artificially motion blur"?
          Hey,
          I should write initially in my response, anyhow you can apply the object properties as select the road geometry -> Right Mouse button click -> V-Ray Tag -> Apply object properties to geometry.
          Check the attached file
            Ok, I misunderstood you. I am already using the override. As it is necessary in some situations, where wheels are to fast..
            I thought there is a new checkbox anywhere..
            So all good, thanks!!
