Is there a good solution of rendering the earth atmosphere?
  • Is there a good solution of rendering the earth atmosphere?
    Hi
    I am rendering some images for a project about the earth. I use the textures from NASA but I struggle with the atmosphere.
    I have tried using fog, and a sphere with fall off and it look ok from distance but close up I need the effect in the example image I attach.
    The problem is to get it to fade out softly in space.
    Any good ideas?
    Rickard
    Originally posted by RickardAx View Post
    Hi
    Any good ideas?
    Rickard
    Here you will find the same topic: https://forums.chaos.com/forum/v-ray...here-challenge Inside the posts you will see several methods to do that, mine is done using C4D
    3D Scenes, Shaders and Courses for V-ray and Corona
    NEW V-Ray 5 Metal Shader Bundle (C4D/Max): https://www.3dtutorialandbeyond.com/...ders-cinema4d/
    @3drenderandbeyond on social media @3DRnB Twitter
      Hi
      Thanks for the Link!
      It was helpful. I have tried some different methods and the best I tried is a environment fog with a object outside controlling the fog falloff with a VrayDistance texture in the fog transparency.
      Your render is really beautiful!!
