Gobo on V-ray light
  • Gobo on V-ray light
    Hi, I need help with applying a gobo texture to V-ray light, just a bw image, is there a way? To cast shadows on an object. Somehow i can't figure it out, applying texture to small area light does not work.
    I’ve posted a setup here some time ago, if you look in my posts you should find it
    3D Scenes, Shaders and Courses for V-ray and Corona
    NEW V-Ray 5 Metal Shader Bundle (C4D/Max): https://www.3dtutorialandbeyond.com/...ders-cinema4d/
    @3drenderandbeyond on social media @3DRnB Twitter
      sirio76 Thank you, I will have a look!
        Hello lukas_kostka,
        We have an article, explaining how to do that for V-Ray for 3ds Max, which you can find here. You can follow the same steps in V-Ray for Cinema4D as well. Let me know if you need further assistance.
        Aleksandar Kasabov
        chaos.com
          Originally posted by aleksandar.kasabov View Post
          Hello lukas_kostka,
          Thank you, this works, but when I change the light color the light remains white. Maybe it could be solved with VRaySoftbox map as you mention in Max tutorial, but I cannot find it in Vray5 for C4D. Can you help me where to find it? Thank you.
            Hello lukas_kostka,
            Please note that the V-Ray Softbox shader is not available in V-Ray 5 for Cinema4D. It is only available in V-Ray 6 for Cinema4D beta. You can find more information about the shader here.
            Aleksandar Kasabov
            chaos.com
