HVAC system modelling and visualization
  • HVAC system modelling and visualization
    I have to model and render an HVAC System (image attached). And sorry, might be a bit off-topic VRay
    1. Does anyone have experience with the Air Duct Generator for C4D? Will it work in R26?
    2. I am looking especially for a Spiral Duct Texture - can someone share one? Or I am willing to pay for it - or not sure if a script exists to create a spiral duct from a spline.
    3. Or would it be easier to use a pipe and then apply a spiral bump through a C4D VRay shader?
    Thank you in advance!
    Don’t know about the air duct generator, seems assets based so you may probably reuse the mesh components. I would simply model the thing, it can be done procedurally using several helix and deformer and loft tool. Since the components are modular you can build the straight tube, the bend etc and then assemble all of them using render instances. For the shading we have this tutorial on our channel (is for Corona but you can do 100% the same in Vray): https://www.youtube.com/watch?v=WIK8UdxGj3M
    3D Scenes, Shaders and Courses for V-ray and Corona
    NEW V-Ray 5 Metal Shader Bundle (C4D/Max): https://www.3dtutorialandbeyond.com/...ders-cinema4d/
    @3drenderandbeyond on social media @3DRnB Twitter
      thank you - that is great and helpful. Well, the problem is that it is an HVAC System for a conference hall, different systems etc. just was looking for a way to speed up modelling
      But the render tutorial is excellent.
