Hi!
I'm having a few issue - but mostly a bunch of questions- with the cryptomatte RE. Some of them are regarding the documentation, others are with the usage.
One thing that caught my eye is:
Sorry if this was more of a rant and a cry for help but most of the forum doesn't cover these questions and i feel like there is probably a lot of potential that i'm missing, but i just don't understand the documentation without easy to understand examples
Thanks for reading!
- I was wondering if there was a way to save the cryptomatte element separately in one exr or vrimg file? I have this option in octane and redshift. and sometimes its easier to use because if materials change in a project but the animation stays the same i can just reuse the cryptomatte i already have. Is there a reason that some render engines save the cryptomatte re separately and vray doesn't? Are there any advantages or disadvantages to this approach?
- When I save exr files containing cryptomatte re-s with the VR output system and i import them into After effects i get strange duplication when pre-composing the exr channels. The ORANGE layers are empty and only the red layers contaion the real information. This means that eighter AE reads and pre-comps the exr files wrongly or vray saves some empty layers? Anyone had this issue before?
- "Only requires a fixed number of additional render elements, typically four." what are those render elements? Are they necessary? what does this mean? are these extra layers that are unavailable in the exr?
- Node name and Node name with hierarchy.
- I get the same result in complex files where there is a bunch of parent and child relations, but id don't get what is the real differenc and when could it be usefull to use one over the other.
- Node material name – Creates mattes based on the materials in the scene.
- Ok this sounds great but this still has the issu with layered materials and stacked materials just as the multimatte id re and others.
- Node asset/reference name – Creates mattes based on Cinema 4D References made within the scene. Note: This does not create mattes based on Cinema 4D Assets, only file references.
- I have no idea what this means. Is this for xrefs? or imported alembic files? I've never hear of cinema 4d references. is this a name for something really basic i don't get?
- Node user attribute – Creates mattes from a property specified in the User Attribute field.
- User Attribute – Specifies a user-defined attribute for creating ID mattes when ID type is set to V-Ray user attribute.
- Ok, so i don't understand any of this regarding c4d. can anyone explain what does all this mean and how can i use vray attribtes and other user defined attributes? I could imagine this is something usefull but currently i have no ide how to make use of it. and If I'm correct this sentece says that the id type is node user attribute and if this id type is set to vray user attribute (this doesn't exist as an id type) then you can set custom ids? is this some kind reference loop I'm missing?
- Id Type Prefix – The text added to the beginning of the rendered file, when saved as a separate file (e.g. myrender.cryptomatte.exr).
- I don't think this feature works. I've chose the node layer name id type and wrote "testid" and this string doesn't show up anywhere nor is it saved into a separate file ( first of i thought that this way i can save the specific cryptomatte re to a separate file but this was not the case) what are the use cases for this?
- Add Root Object Name – When ID Type is set to Sub object name, it specifies what information about the sub object names goes into the Cryptomatte manifest.The dag path and the sub object name(s) (e.g. MeshName.abc/ObjectName) is added to the manifest.
- Again, i understand the principle, but i have no ide how should i use this information, or how could i use it in comp (fusion, nuke, ae)
Thanks for reading!
