There seems to be something wrong with the vector displacement of vray
  • There seems to be something wrong with the vector displacement of vray
    Using the map in the file, I can't get a correct ear displacement. I don't know if it's my wrong setting
    Hello 123456_,
    The attached texture works just fine on my end. You might need to bump up the displacement amount to see the displacement. Please check this screenshot.
    Aleksandar Kasabov
    chaos.com
      Originally posted by aleksandar.kasabov View Post
      Hello 123456_,
      As I screenshot, the left is made with the c4d displacement modifier, and the right is made with the vray displacement. Obviously, the vray displacement is incorrect
        Hello 123456_,
        Is your test result correct
          Did you create the vector displacement in ZBrush?
          Unfortunately V-Ray does not support ZBrush vector displacement.
          I've been requesting support for quite some time, but Chaos seems reluctant.
          OakCorp Japan - Yuji Yamauchi
          oakcorp.net
          v-ray.jp
            Okay, I see
              Here is how to use ZBrush vector displacement with V-Ray: https://docs.chaos.com/m/mobile.action#page/86640816
              is this not working for you?
                have you actually tried it?
                This tutorial does not have an explicit Switch value. Why?
                There should be no Switch value that fully reproduces the ZBrush Diagnostic Files (which would be spherical).
                oakcorp.net
                v-ray.jp
