When the value of Geometry samples is greater than 2 in the vray gpu mode, the moving object disappears
  • When the value of Geometry samples is greater than 2 in the vray gpu mode, the moving object disappears
    I uploaded the project. This problem will occur when rendering the animation, but it will not occur in a single frame, as shown in the picture Click image for larger version
    Hi 123456_, this seems to be bug on our side (which I logged for fixing as VC4D-1616). In the meantime, there are two workarounds you can use render the object:
    1. You can try to use the bucket image sampler
    2. You can try to force dynamic geometry usage (see the attached image)
    Deyan Hadzhiev
    Developer
    chaos.com
      Thank you for your solution
