I have a scene where I need to use an AO map as ground shadows. I will be doing some light compositing in photoshop and my images need to have a transparent background, so I would need to have a separate element with just the AO map from the ground plane since a want to be able to manually adjust how strong it is in PS, and not have it be effected by any elements I might add.
I have added an AO map in extra tex element, and have it include only the ground plane. I’ve also added a VrayObjectProperties-tag and played around with the settings, but haven’t been able to achive the desired result.
Any suggestions? I need the usual render elements (lighting, GI, reflection etc) but without the ground AO map visible in those, and I need an extra render element with just the ground AO map.
