C4D VRayNoiseTex
This topic has been answered.
  • C4D VRayNoiseTex
    What happened to the VRayNoiseTex?
    I can't find it anymore : (
  • Answer selected by viktor_angelov at 14-06-2023, 11:03 PM.
    Hello Rickmc
    Thank you for clarifying. As mentioned above, the VRayNoiseMax texture is currently unavailable. However, it can be used with V-Ray Node Materials.
    You can use the Cinema 4D's Noise texture instead: http://ftp.chaosgroup.com/support/sc...4_12-04-42.jpg
      Hello Rickmc
      VRayNoiseTex is a texture for noise in V-Ray for 3Ds Max.
      Are you referring to VRayNoiseMax texture? Please, be aware that the texture is currently unavailable. However, it can be used with V-Ray Node Materials.
      Would you let us know why do you want to use this specific texture and not the Cinema 4D's Noise texture?
        Sorry, I was wrong, I mean the Noise Shader, not Cinema´s Noise
          Hello Rickmc
          As mentioned above the VRayNoiseMax is currently unavailable. Instead you can use the Cinema 4D's Noise texture: http://ftp.chaosgroup.com/support/sc...4_12-04-42.jpg
          Please be aware that the VRayNoiseMax Node texture is available for use.
          If this does not answer you question, please give us more details regarding the feature you are looking for. A visual representation would be useful as well as the version of the V-Ray you are using.
            I miss this guy:
Name:	Bildschirmfoto 2023-06-14 um 12.07.47.png
              Hello Rickmc
                Sadly, VRayNoiseMax was better than first expected.
                If I get it over the Node system, ok
