Animate displacement
  • Animate displacement
    Hello there,
    got a short question. I want to have displacement around a moving object.
    Thought the best way to do that is the vray distant shader, but it doesnt seem
    to work in the vray geometry tag.
    any suggestions?
    Edit: Something similar what you can do with the c4d displacer deformer and field falloff
    Hello folklore
    I tested the Displacement and the animation works as expected by default.
    Could you share with us a visual representation of what you are trying to achieve so we can assist you?
      Sorry for coming back so late, but had to finish the project and forgot about this.
      I attached a simple setup. It seems I cant get distant shader in the displacemnet tag working.
      The color material works as intended. Where's my error?
        Hi folklore​,
        Please note that the 2D Displacement type is not working with procedural maps. If you switch the Type to Normal, it should work correctly.
          thank you. good to know
