Help Update Vray problem
  • Help Update Vray problem
    Good morning
    I updated vray (vray_adv_62000_c4d2023_x64)
    and I no longer have vray in C4d.
    The vray renderer no longer exists.
    Same in extensions
    URGENT​ Click image for larger version  Name:	Capture d'écran 2023-12-12 152425.png Views:	0 Size:	25.7 KB ID:	1197340 Click image for larger version  Name:	Capture d'écran 2023-12-12 152435.png Views:	0 Size:	46.6 KB ID:	1197341
    Thanks
    Hi azeofmars, can you share your exact version of Cinema 4D? Also it would be helpful if you could check for any error messages in the console, that might have been reported when V-Ray was loading.
    Deyan Hadzhiev
    Developer
    chaos.com
        Install vray_adv_62000_c4d2023_x64
          I just installed c4d 2024 ''Cinema4D_2024_2024.2.0_Win''.
          I downloaded vray ''vray_adv_62000_c4d2024_x64''.
          And it's impossible to install true. Here is the message
            Hi azeofmars , given the screenshots you provided, I think the problems you have are the following:
            For the Cinema 4D 2024 version - the error dialog from the installer indicates that you have a broken download, so you should try downloading the installation anew and this should fix the problem.
            For the Cinema 4D 2023 version - since V-Ray 6.10.01, we require update 1 of Cinema 4D (so you should update your Cinema 4D to version 2023.1 or newer, it would be best to use 2023.2.2). Sorry for the caused inconvenience, the minimum required version of Cinema 4D is listed in the download page here, and may be easily missed.
            Deyan Hadzhiev
            Developer
            chaos.com
              Thanks for your feedback
              For C4d 2024 I re-downloaded ''vray_adv_62000_c4d2024_x64'' and it works GREAT.
              For C4d 2023 I cannot update the version of c4d​
                Hey azeofmars,
                You can try updating Cinema 4D via the Maxon One app if their website doesn't work for you.
                Ivan Shaykov
                chaos.com
