Add a new layer to freeze vray vfb
  • Add a new layer to freeze vray vfb
ID:	1224033 I recorded a demonstration video of the problem, and I'm not sure if it's just me who encounters this issue. It seems that it's not really frozen. I just need to minimize the VFB of Vray and then restore the window, and the freeze can be resolved
    Hi 123456_ Thank you for sharing this. I am currently unable to replicate the freeze on my end.
    Could you please share which Cinema 4D and V-Ray versions are you using?
      The C4D version is 2024.4. Is it possible that this is a problem with the Windows system, as I did not experience this freezing situation when using VRay before, but it is normal for me to use 3dmax VRay on this computer Click image for larger version
        Hi 123456_ Is it correct to understand that you are using Cinema 4D 2024.4.0 ?
        If you have never had this before you could try installing an older version of V-Ray to check if the freeze will appear again.
        Meanwhile, I tested with Cinema 4D 2024.4.0 and 2024.4.1 with your V-Ray version and could not reproduce the freeze.
          I feel like it might be a problem with the Windows system, as I have older versions of VRay and C4D on my computer. Previously, there were no issues, but I don't know why this freezing phenomenon occurs now. When it freezes, I can also unfreeze it by scrolling the mouse wheel
            Have you performed any Windows updates recently? You could check this at Windows Settings > Windows Update > Update History.
            I am asking about the versions as the specific combination might be causing the issue. Do all of your C4D versions on the same computer have this Freeze ?
              Yes, the C4D version is 2024.4.0, and all versions on the same computer have this issue,I have not performed any Windows updates
                Although I don't know why this happened, the newly released VRay 7 has fixed this issue
                  Great to hear 123456_ Enjoy your time with V-Ray 7!
