Adding VRayDistance to Geometry as a displacement texture has no effect on the final rendering
  • Adding VRayDistance to Geometry as a displacement texture has no effect on the final rendering
ID:	1224290 Click image for larger version
ID:	1224289Interactive rendering allows you to see displacement effects, but the final rendering doesn't work. I uploaded a demo video, is this a bug?
    Hi 123456_ We appreciate you sharing this with us! I tested this set-up on my end and it works as expected. Video attached below.
    Please, let me know the versions of V-Ray ( V-Ray > Help > About ) and Cinema ( Help > About ) that you are using.
      I uploaded a file, can you try to see if it works properly? Also, your video cannot be played
        The C4D version is 2024.4. Click image for larger version
          Hi 123456_ The order of the objects in the Objects Section affects the result. You need the Plane geometry above the Cube. Please, refer to the image below and let us know if it works for you once you test it.
            Thank you for your answer. He is now working normally. Why does this order affect the results
              123456_ We will be looking into it. I have logged it into our system [VC4D-2586]
