Chaos Scatter using VRayDistance has no effect
  • Chaos Scatter using VRayDistance has no effect
ID:	1224993 Just like in the picture, there was no effect. I uploaded a demonstration video and engineering files
    Hi
    just tested fast on new v7 in one of my files:
    for me this works(i converted object to poly though), i set outside solid to white, inside (inside seperate) to blk
    all inside the cube is without any scatter objects
      Originally posted by stefan_laub1 View Post
      Hi
      Can you test it with the engineering files I uploaded
        Hi 123456_ Could you place Geometry A below the Chaos Scatter ( but not inside ) in the Object menu and let me know if this resolves the issue?
          This is indeed effective, but there is no preview in the viewport. Similarly, using distance nodes, the corona viewport looks like this Click image for larger version
ID:	1225070 Click image for larger version
            Great to know it works.
            Was there preview before rearranging the geometries in the Menu ?
              I tested again, and as long as VRayDistance is added, there will be no preview
                I have logged it into our system [VC4D-2633] and it will be looked into. Thank you for taking the time to share all of that with us!
