Can VRay achieve a similar SSS effect?
Nihao,
The best and most accurate result you can handle with https://download.chaos.com/vrscans?q=scatter -> Wax material. with SSS and Alsurface also can handle these results.
I will search in main files to provide you some ideas.
Cheers,Boyan Nalchadjiiski | QA Engineer @ Chaos |
E-mail: boyan.nalchadjiiski@chaos.com
Cheers,
Originally posted by 123456_ View Post
A while ago I’ve posted some sss setups, maybe they can help:
https://forums.chaos.com/forum/v-ray...-sss-on-vray-53D Scenes, Shaders and Courses for V-ray and Corona
Also, in this specific case you can get a similar result even without sss by adding an inverted ambient occlusion on top of a standard shader.3D Scenes, Shaders and Courses for V-ray and Corona
Hey,
Yes, I will try it.Boyan Nalchadjiiski | QA Engineer @ Chaos |
I'm not material expert, but I think this should be achievable simply with good values for SSS Color and Scatter radius in a V-Ray Material. Here is my fast attempt, it could definitely be improved, but as sirio76 mentioned above, probably an identical result is impossible, because these are different engines after all.
Here is the modified scene with the V-Ray Material.
- Likes 3
