Cosmos Browser don't download Textures
  • Cosmos Browser don't download Textures
    Hi Forum,
    when I download a texture or model from the Cosmos Browser, the bitmaps of the texture are not loaded. Does anyone know a solution?
Name:	Bildschirmfoto 2025-02-20 um 10.47.48.png
    Hi Rickmc
    Does this happen in every scene? Even new ones?
    What V-Ray build are you using?
    Does it happen with every texture?
    Check Windows > Project Assets Inspector if everything is connected correctly
      C4D R21 / MAC OS
      Yes, it happens with every texture and even in a new project
        Hi Rickmc,
        In V-Ray 7 materials from Cosmos are imported as nodes by default so you are most likely using the wrong node space. Can you make sure that either V-Ray or Current is selected in Render/Node Spaces. Both of them should work the only difference being that Current will change the node space depending on the render engine you are using(so you would have to also make sure that V-Ray is your selected render engine in your render settings). Let me know if this fixes it.
        ​​Click image for larger version
          Thats it.
          Thank you very much
