Switching views can cause crashes
  • Switching views can cause crashes
    When I use VRAY7, switching views always crashes, but whenever I cancel the node preview before switching views, there is no problem, or when I convert all to classic materials, there is no problem. However, when I convert to nodes again, it still crashes. I found that it only works this way on this computer. My home computer can be used normally, but I believe there will be other users who will do the same.
    Hey aya_akka,
    Do you happen to be using a G-series AMD CPU, 7950X or any other AMD CPU with integrated graphics? If that's the case can you try a more recent stable build​? If you are still having problems please share a bugreport and minidump(located in %appdata%/Maxon/Maxon Cinema 4D 2025/_bugreports).
      I often encounter the situation where when I click the middle mouse button to bring up the four views and operate on one of the views, there is a high probability that the program will become unresponsive.
