How to render C4D simulated fireworks in VRay
Fireworks volume
Hi aya_akka Please, provide us with a scene so we can see the set-up. I assume you have some particles in the scene to simulate fireworks. In this case you would need V-Ray Particles and then adjust the values depending on what you are looking to achieve.
You can read more about V-Ray Particles here: https://docs.chaos.com/display/VC4D/V-Ray+Particles
Originally posted by viktor_angelov View PostHi aya_akka Please, provide us with a scene so we can see the set-up. I assume you have some particles in the scene to simulate fireworks. In this case you would need V-Ray Particles and then adjust the values depending on what you are looking to achieve.
You can read more about V-Ray Particles here: https://docs.chaos.com/display/VC4D/V-Ray+ParticlesAttached Files
I just simulated the fireworks in the C4D simulation tag briefly. The cache volume file needs to be at least 2g, and uploading it takes too long. Playing this file will produce fireworks, or can you demonstrate using C4D to simulate fireworks and then render it?
