Camera Problem
  • Camera Problem
    Hello,
    can it be, that the Tile and Shift setting of the PhysicalCamera does not work with Pinhole?
    best regards
    uwe
    shift works kin pinhole modus,
    tilt? i can change the parameter but honestly i dont know what it is....
      here it works, use the x,y shift inside the c4d camera(the native c4dsettings)
        same here, tilt doesnt do a thing. using a default vray camera (vray5). shifting works fine.
          With the pinhole camera the vertical shift does not work for me either. When will this be fixed? The function is very important for our office workflow. I guess we will have to wait until this bug has been fixed.
            Hello,
            This has already been reported to our developers (bug ID: VC4D-698 ). I will bump its priority and will keep you updated. Thank you!
            Aleksandar Kasabov
            chaos.com
              I can't wait to start working with the new V-Ray 5 - Bump
                Hello,
                We do not yet have any updates on this. I will let you know as soon as we have more information.
                Thank you for your patience.
                Aleksandar Kasabov
                chaos.com
                  Is there any update on the pinhole vs standard mismatch? and also is there a way to make the pinhole work with shift film/ vertical-horizontal shift?
                    Hello akos_kiss,
                    I am afraid that we don't have any updates on the matter yet. We will let you know as soon as we have more information to share with you.
                    Aleksandar Kasabov
                    chaos.com
                      Here is what worked for me. Just tick the "specify Field of View" box in the camera settings and the shift should work with the camera set to pinhole.
