Hi CG,
I have some questions!
1.
Iam Using a Ryzen 9 3900X 12 Core (24 Threads) CPU.
When using Renderenging -> V-Ray to use CPU in progressive mode it uses just 20% of CPU Workload.
In Bucketmode its 100% it seems.
Why is that the case? the rendering is finished faster in Progressive than in Bucket even though it seems only using 20% CPU. What is happening here? The scene is just a product, V-Ray Sun with sky, Light Cache GI, Physical Cam. Nothing changed.
2. I have an RTX Card. What is the difference between RTX and CUDA? Nothing mentioned in the manual.
3. Which mode should I prefer using?
4. When using RTX I cant combine this with my CPU?
5. Are there any quality differences when using each of those modes?
6. Biggest problem or V-Ray was/is that it has to prepare every Frame/Scene. When using Interactive Rendering you can animate stuff WITHOUT to prepare the scene every time. Could this be used for Final Rendering so every frame renders extremely fast?
Thx in advance!
Greets,
PdZ
1.
Thx in advance!
Greets,
PdZ
