3d noise via distributed rendering
  • 3d noise via distributed rendering
    Hi chaos group,
    I'm using a cinema noise shader in 3d space for a large water scene. Local rending is great but calculating the pictures via distributed rendering the noise is not working.
    The "VrayC4DBake" converts the shader just into a 2D Texture and doesn't work in my case. Is there any chance to use the 3d noise of cinema?
    Why is it working local but not DR? Thx in advance.
    Hello,
    This is a known issue which has already been reported to our developers (bug ID: VC4D-793). I will let you know once we have mo
    Aleksandar Kasabov
    chaos.com
      Hello klex167 ,
      This issue is fixed in the latest stable builds. You can download and install it from here:
      https://nightlies.chaosgroup.com/mai...table/20210129
      Aleksandar Kasabov
      chaos.com
        Thank you Aleksandar, this is working perfectly now!
        Unfortunately there is a new issue with rendering via DR:
        I'm changing the perspective with a stage animation: 4 frames with 4 different perspectives. But the slaves are not changing correctly. Please see the pictures.
Name:	dr rendering.jpg
        Do you understand my problem?
          Hello,
          We are aware of this issue and it has already been logged into our internal bug-tracking system. I will let you know once we have any updates on that.
          Aleksandar Kasabov
          chaos.com
            Dear klex167 ,
            Is it possible to share the scene in question so we can have a look at it and check if this is regarding the same issue as the one we have reported on our end?
            Thank you.
            Aleksandar Kasabov
            chaos.com
              Hi Aleksandar, here is a little scene that is not working properly.
                Hello klex167 ,
                Upon testing your scene I was unable to reproduce this issue. Can you please share more information about the exact version of Cinema4D and the build of V-Ray that you are using?
                Aleksandar Kasabov
                chaos.com
                  Hi Aleksandar,
                  I installed the latest build 30573 from 03.02.2021 (nightlies) on my workstation and the slaves.
                  I'm using "Cinema 4D R23.110" with "V-Ray 5 v5.00.42 from Feb 2 2021".
                  The slaves have "V-Ray core version 5.00.40, build 30573 from Feb 2 2021".
                  Starting the scene and rendering produces the following result.
Name:	dr test 01.jpg
                    Hi klex167, we have reproduced the issue and there is already a potential fix for the problem, it may soon be available in the stable nightly builds.
                    Deyan Hadzhiev
                    Developer
                    chaos.com
                      Thanks a lot!
                        The issue was solved with todays build. Thank you!
                          Hello,
                          That is correct. The issue has been fixed in the latest stable builds. You can download and install it from here:
                          https://nightlies.chaosgroup.com/mai...table/20210209
                          Aleksandar Kasabov
                          chaos.com
