issue 2D displacement
  • issue 2D displacement
    Hi there, everytime I try to render a skin with 2D displacement to retain all the details of the map, Vr5 gives me a chaotic result as you can see in the "red" picture. As if the UVs were moved also .
    The correct one is same skin test with "normal" mode active.
    Any suggestions?
    by the way, also sometimes: modifying the quality parameters , "view dependent" and Edge length result in a render with parts of the volume "cut of" as if a boolean op was active. very strange
    Thanks
    P
    Vray5 cinema R23 pc windows10
