Lightmix settings are not loading
  • Lightmix settings are not loading
    I render one shot with different elements, lights, illumination etc included in the lightmix.
    In VFB I change the color and power of light in selected elements and save the lightmix settings to a file.
    I render the second shot from a different perspective, with the same elements. But after reading the lightmix parameters from the file, these parameters are not loaded. Again, I have to manually set all the parameters with my eye, set the colors, power, etc. So far I use a pencil and note the value of the changed color and the power on the sheet, so that I can set it in the same way during the next shots.
    Upon testing I was not able to reproduce the issue. Could you please share the scene in question and the .lightmix file so we can have a look?
    Aleksandar Kasabov
    chaos.com
      It works just fine on my side as well, maybe share a screen recording?
        For me, after changing the camera, light mix layer settings (colors and value) are reset. I save these settings to disk, but loading them doesn't help.
ID:	1102682Click image for larger version
          Hard to say what's going on without a scene. Maybe try to re-create that on a more basic scene (cube with a few lights), so you can share it.
            I will try to recreate that in a simpler scene.
            For now, the only thing that comes to mind is that this only applies to lights that are copies. These four ceiling lamps.
