Multiple Object ID's dont render with same name
  • Multiple Object ID's dont render with same name
    I noticed in my project that only the last Object select ID was rendered.
    After a lot of trial and error I found that the names of the object select render elements need to be different for them to be rendered.
    This is of course an easy fix. But very annoying if you don't know this. So hopefully it can be fixed
    Hello floris_drupsteen ,
    Upon checking I was not able to reproduce that. Could you please share the exact versions of V-Ray and Cinema4D. Also, please share a test scene where the issue is reproducible.
    Aleksandar Kasabov
    chaos.com
      Hi Aleksandar,
      I have attached 2 files in a zip.
      My system is Windows 10; C4D R23.008; Vray V5.00.43 from Feb 22 2021
      files.zip
      and render results (with/without renamed Render Element)
      Hope this helps you find it.
        Upon testing it seems that this only happens when rendering in Picture Viewer but it doesn't happen if rendering with VFB2. I have reported this in our internal system and I will let you know once we have more information.
        Aleksandar Kasabov
        chaos.com
          I also discovered the same issue, i am following this thread so i know when it is fixed.
