Issue rendering Motion Blur
  • Issue rendering Motion Blur
    Hello,
    I have an issue rendering motion blur with a mixamo rigged animation.
    When rendering in animation mode, mb appears only on the first frame.
    If I render any frame as still, mb is ok?
    Any idea what's wrong?
    Thanks
    Did another test, same result... when rendering animation, MB is not working.. 1st frame ok, following frames no MB...
    Please, tell me I am doing something wrong... using latest nightbuild
    Click image for larger version  Name:	wheel0000.jpg Views:	0 Size:	56.7 KB ID:	1104802Click image for larger version  Name:	wheel0001.jpg Views:	0 Size:	61.0 KB ID:	1104803Click image for larger version  Name:	wheel0002.jpg Views:	0 Size:	62.3 KB ID:	1104804
      Hi haniel1107, I can not reproduce this issue. Neither with the last official release (hotfix 1), nor with the latest stable nightly build.
      Can you share a simple scene that reproduces the issue? Also, would you describe exactly what render setup are you using (with/without DR, with VFB or Picture Viewer, command line)?
      Deyan Hadzhiev
      Developer
      chaos.com
        Hi Deyan, the scene with the runner is above (First Post in a zip).
        R23 with the latest night build on Windows. Threadripper 3990X / 128 GB Ram / RTX 2080Ti
        Rendersettings all by default, with VFB, no DR.. Anything else you would need?
        Thanks..
          Hi Deyan, made a 2:22 Video.. as said before everything by default except render time for this video...
          https://www.dropbox.com/s/q6vjqbcrm4...14736.mp4?dl=0 (when downloading the video, quality will raise...)
            Here is the simple scene with the wheel
              Same happens on ChaosCloud
              Click image for larger version  Name:	Screenshot 2021-03-01 12.27.05.png Views:	0 Size:	289.8 KB ID:	1104996Click image for larger version  Name:	Screenshot 2021-03-01 12.26.59.png Views:	0 Size:	320.4 KB ID:	1104997
                We reproduced the issue with both your scenes. I'll investigate this today.
                Deyan Hadzhiev
                Developer
                chaos.com
                  Thank you!!
                    Hi Deyan,
                    could you figure something out?
                    If I add a simple cross in the back, the cross got MB on the following frames...
Name:	Screenshot 2021-03-02 07.29.11.png
                      Hi haniel1107, I managed to pinpoint the problem yesterday and will finish fixing it today - the fix will be available in the stable builds in a day or two.
                      Deyan Hadzhiev
                      Developer
                      chaos.com
                        Super, thank you very much!
                          Hi Deyan, do you know if the fix is really coming today? Just need to know it, otherwise I have to go back... to 3-7
                          I am a small player, I need to keep my promises...... to my customers
                          -Thanks
                            Hi haniel1107, sorry for the delay. During the testing of the fix we unveiled a deeper problem that will require further effort. I'll keep you updated, but probably the fix will not make it to the stable nighty builds tonight or tomorrow.
                            Deyan Hadzhiev
                            Developer
                            chaos.com
                            • #15
                              Ok thanks for the answer... then I think it is safer to switch back.. as for the deadline....
