VRayMultiSubTex not working correctly on VRay Proxy in GPU mode
  • VRayMultiSubTex not working correctly on VRay Proxy in GPU mode
    Hi everyone,
    It seems like there is generally a bug with the VRayMultiSubTex and option "Random by Render ID" in combination with VRay Proxy in GPU mode. I try to randomize every cloner instance of the proxy by that shader, but it's not showing random colors in GPU mode - while it does in CPU mode.
    I tried already different ways of exporting the .vrmesh or assigning texture in different ways. The same setting (for MultiSubTex) is working for a regular polymesh in the cloner just fine (see in the file). I tested a lot to make sure that my settings don't cause the issure, but maybe I'm doing something wrong here?
    I attached for you some pictures below and a file that contains the scene and the mesh. Could you please have look?
    Thanks,
    Felix
    Hello felix_brner ,
    Thank you for highlighting this for us. It seems to be a bug and I have reported it to our developers (bug ID: VC4D-839). I will keep you updated on the progress.
    Aleksandar Kasabov
    chaos.com
      Thank you!
      By the way: the same behavior occurs with both supported file types - .vrmesh and .abc - and the option "Random by Face material ID".
        Dear felix_brner ,
        Thank you. I have mentioned those details as well and I will let you know when we have any updates on the matter.
        Aleksandar Kasabov
        chaos.com
