Flat projection texture tiling issue.
  • Flat projection texture tiling issue.
    Hello I was trying to use a flat projection of a texture. I don't want it to tile. I was using a blended V-Ray material. Tiling is turned off and it looks fine in the viewport but when I render it with the RT render it looks like the tile setting is turned on. Is this a known bug? Is there a workaround?
    Originally posted by benjamin_ferrante View Post
    Hello I was trying to use a flat projection of a texture. I don't want it to tile. I was using a blended V-Ray material. Tiling is turned off, and it looks fine in the viewport but when I render it with the RT render it looks like the tile setting is turned on. Is this a known bug? Is there a workaround?
    Hi benjamin_ferrante ,
    Thank you for the feedback. Yes it is a known issue, and we're currently working on fixing it. We will update the thread as soon as we fix it or have more information on it.
    Ivan Shaykov
    chaos.com
      Hello benjamin_ferrante ,
      This issue has been fixed and it is available in V-Ray 5 for Cinema 4D - Hotfix 2. You can download and install it from here.
      Aleksandar Kasabov
      chaos.com
