There's an issue with the scene/material conversion from 3.7 to 5. If you have a file with different takes, you will lose all overrides on the light-tag (3.7.) which relate to either size OR intensity of the light. Would be nice to have this fixed as different light settings are a common workflow inside the take system.
Scene conversion 3.7 to VRay 5 - light issue
Hi Berndimator ,
Could you please send us a test V-Ray 3.7 scene where the issue is reproducible so we can have a look?
Thank you.Aleksandar Kasabov
chaos.com
Hi aleksandar.kasabov , I'm very busy at the moment. I attached a screenshot hope this helps? The problem occurs when the light is parented to a Null (didn't know this when I posted the first time).
Hello Berndimator,
Upon further testing, I found out that the transforms of the lights (position, rotation and scale) are not converted. Other parameters, such as intensity or the size of the light (when set from V-Ray light tab> Area light rollout> size) are converted. I have reported this to our developers and will let you know once we have any updates.
chaos.com
