Adding an 'object properties' tag to any object while in the interactive render crashes Vray
  • Adding an 'object properties' tag to any object while in the interactive render crashes Vray
    Not sure if this has been reported yet, but Adding an 'object properties' tag to any object while in the interactive render crashes Vray. C4D also hangs, and you also can't start a new render until you force quit C4D after this happens. Thanks!
    Hello scott_canuel ,
    Upon testing this seems to be happening when using V-Ray GPU only. I have logged it in our internal bug tracking system (bug ID: VC4D-891) and I will keep you updated on the progress.
    Thank you.
    Aleksandar Kasabov
    chaos.com
