Issues with Object Properties Tag
  • Issues with Object Properties Tag
    Hello,
    I use: "Object Properties Tag -> Surface Properties -> Generate GI Multiplier" in the GPU DR rendering I get a faulty rendering. The object is partially rendered without texture. If I render in CPU mode, everything is fine.
    Best regards
    uwe
    Hello pardalis ,
    The Generate GI Options in the VRayObjectProperties tab do not seem to work with V-Ray GPU and I have already reported the issue to our developers. (Bug number: VC4D-897). I will let you know once we have any updates.
    However, during my tests I didn't experience any issues with partial rendering of textures. Is it possible to share a test scene where the issue is reproducible so we can have a look?
    Valentin Leondiev | chaos.com
      Hello valentin_leondiev ,
      the problem with the texture cannot be reproduced and unfortunately I cannot send you any data because the customer does not give permission.
      Best regards
      uwe
        Thank you for the feedback pardalis. If you manage to reproduce the issue in a separate test scene that you are able to share with us we will be happy to take a look.
