Resolved : due to auto_white balance ;;;;CRASH since yesterday unable to render anything
  • Resolved : due to auto_white balance ;;;;CRASH since yesterday unable to render anything
    Everything went normal, untill yesterday where my Vray5 for c4D began to crash on sam erenders it was able to render the morning . I have to reboot the computer everytime because the screen freezes . Super anoying in mid-production !
    Any idea?
    thanks
    another console grab
      seems like all the system is going mad
        crashes when i activate the override tab Auto_white balance", must be that, because it renders nicelly when the option is not active
          Same here, I installed latest nightly and was impossible to render: Always a popup with "core problem". I reinstalled the previous and worked witout problem
            Hi, can you give an example scene or the crash dump files, so we may either reproduce this or check the dump.
            Juan Ferreira - can you give an example scene that reproduces this? Are you using V-Ray GPU and is it CUDA or RTX?
            Deyan Hadzhiev
            Developer
            chaos.com
              hi Deyan, I was rendering on CUDA (2 X RTX5000 + 10cores XEON) The crash is very mysterious thing, sometimes it renders ( like now), but at one moment it seems the whole system is going crazy. I first thought also it was a question of reached GPU limits on my computer, but as you could see in the screen grab the render uses 4 or 6 out of 16GB for each card. I reduced some 4K maps to 1K or 2K, it renders well. Pushed them again to 4K and.. renders well untill I try a render with "auto white balance". The absurdity of the event is that I tried again a few minuts ago and ... no bug or crash at all, all seems right. It is clearly something strange. Where can I locate the crash dump file?
                another crash right now: as the Vray advanced Bitmap option is noat available for now in the menu, I put a Vray Bitmap channel inside a C4D filter, to correct the brightness of a color map. Went well but after a few minuts... crash. Can this kind of trick be responsible for all the crashes in my machine?
                  I'm attaching a screenshot with the possible location - note that the directory should be different on your machine. You can easily open it from Preferences -> Open Preferences Folder, and check its _bugreports subdirectory.
                  The files that are of interest there are the "_BugReport.txt" and "minidump.dmp".
                  Deyan Hadzhiev
                  Developer
                  chaos.com
                    Hi Deyan sorry but I can not send the scene because yesterday I was worked on 4-5 scenes and when my computer did crashed 2 or 3 times I resinstalled Vray and I dont remenber what scene was the first.
                    I can say you that I was rendered with GPU (Cuda), R 21,
                    Attach files that you request
                    If you need something more, tell me please
                      here is a bug report, and the minidump Deyan. Do not know if they are the right ones ..
                        so this is a new crash: just modified the vignetting parameter of the camera from 6 to 10 . Rendered without problem before, (and I removed all the filters I had in the material texture editor).
                        It seems like somehow it crashes when modifying some parameters :/ , camera focal length, vignetting or auto white balance for example
                          this kind of message appears every time in the console ... (I downloaded the latest version of the licence server a few days ago). Do not know if the problems are related to this point.
                            came back to driver 460.89 that worked fine untill I changed it for supported driver 461.9. Lets see if everything is more stable.
                            • #15
                              everything seems ok now, no more crashes using previous driver 460.89
