Size dimensions of rectangle lights are wrong/confusing
  • Size dimensions of rectangle lights are wrong/confusing
    In 3.7 the dimension of a light was defined by it's x and y value, which were direct representation of it's with and height. In VRay 5 the size of a Rectangle Light is defined by the U Size and the V Size. The weird thing about this is a light with a U and V Size of 100cm has actually a with and a height of 200cm. For me as a user this is weird and makes no sense.
    Hello Berndimator,
    Currently, the U and V size of the light represents the radius of the light instead of its diameter which causes the confusion. This has already been reported to our developers and I will let you know once there is any progress on the matter.
    Thank you.
    Aleksandar Kasabov
    chaos.com
      Any news on this issue? i just updated to the latest 5.2 version and the sizes are still a bit confusing.
Name:	vray52_lightize_2021-12-11 082906.jpg
        Hello,
        We don't have any new information about this issue to share at this point. I will let you know as soon as we have any updates. Thank you for your understanding!
        Aleksandar Kasabov
        chaos.com
          Hello,
          This issue is now fixed and the width and the height of a V-Ray Rectangle light represent the actual dimensions of the light. The fix is available in our latest stable build and can be downloaded from here.
          Thanks.
          Aleksandar Kasabov
          chaos.com
            Thanks for the update Aleksandar, may I ask what happens to lights from older V5 scenes?
            3D Scenes, Shaders and Courses for V-ray and Corona
            NEW V-Ray 5 Metal Shader Bundle (C4D/Max): https://www.3dtutorialandbeyond.com/...ders-cinema4d/
            @3drenderandbeyond on social media @3DRnB Twitter
              Hello sirio76,
              The size of the lights from older V-Ray 5 scenes won't change and the displayed width and height will be updated accordingly. Please check the screenshots of the official build and the latest stable build where you can see the changes.
              I hope this is of help.
              Aleksandar Kasabov
              chaos.com
                Perfect, thanks!
                  Great news!
