RGB channel without Lens Effects baked in?
  • RGB channel without Lens Effects baked in?
    I'm pretty sure that on a previous test using multi-layer EXRs that the lens effects were only saved as a separate layer. Currently Vray is spitting out the RGB layer with the lens effects baked in. I cannot for the life of me find any checkbox to get a clean plate. I've tried unchecking the 'Apply VFB Compositing and Color Corrections' box in the Common tab, but to no avail.
    Can someone help?
    Cheers,
    To be clear, for a single frame I can turn off the lens effects layer in the VFB, save all channels to single file and that gives me what I want: clean RGB layer + Lens Effects.
    There seems to be no way to automatically do this for animations though.
      Did you try saving and exr from the V-Ray Output? Seems to work fine on my side, both in Nuke and in Ae (check the screenshots)
ID:	1117461Click image for larger version
        Like I say, it works fine saving a single frame out from the VFB, using the Vray output, but when you render an animation, it's baked in to the RGB along with a separate glare channel.
          Take a closer look at the screen grabs. That is a seq of 5 frames, with 2 channels RGBA and Glare. Mixed in post for the final result, meaning the RGBA has no baked-in effects
            Damn, then I've have no idea what i'm doing wrong here:
Name:	Screen Shot 2021-06-23 at 12.06.09.jpg
            Lens effects layer turned off during render:
Name:	Screen Shot 2021-06-23 at 12.09.06.jpg
            Baked in to RGB
Name:	Screen Shot 2021-06-23 at 12.10.09.jpg
              Can you tell me your V-Ray version and pm me the scene file, so I can take a look?
                File sent. Cheers buddy.
                Click image for larger version  Name:	Screen Shot 2021-06-23 at 12.17.22.jpg Views:	2 Size:	69.3 KB ID:	1117473
                  So it looks like this is a bug with Lens Effects and multi-channel EXRs. Writing out a single channel EXR gives me the RGB channel without lens effects + a separate glare EXR. Multichannel bakes the lens effects in the RGB as well giving me a redundant glare layer.
                  (thanks Yunal for your help testing this)
                    Hello KernitTheFont,
                    I apologize for the delayed reply.
                    Upon testing on my end I was not able to reproduce the issue with the multi-channel EXRs. Would you mind sharing the scene and the rendered files so I can have a look? Thank you.
                    Aleksandar Kasabov
                    chaos.com
                      No probs – file sent.
