Node material constant shading
This topic has been answered.
  • Node material constant shading
    When converting scene materials to nodal, I noticed that they are not displayed in constant shading mode. They appear black in the viewport.
    Please, fix it.​​​​​​​
ID:	1117719Click image for larger version
ID:	1117720Click image for larger version
  • Answer selected by aleksandar.kasabov at 13-04-2023, 04:09 AM.
    As was stated by shaio earlier - this is an issue in Cinema 4D itself (it is observable with Standard node materials as well). Unfortunately we can't do anything about this. We have already reported the issue to Maxon, but its priority may be increased if more users request a fix.
      Hey Makushimu.
      Thanks for the report, we will look in to this and get back to you with more info.
      Ivan Shaykov
      chaos.com
        Makushimu this apears to be an issue with Cinema 4D. If you create a Cinema 4D Node material, it will also be displayed black when you select Constant Shading for the Viewport.
        Ivan Shaykov
        chaos.com
          It's not good, because I'm most often working in Constant Shading mode.
          It would be wonderful, regardless of it, if you managed to do something about it.
            Unfortunately this issue still persists (Vray6 C4D2023). Would be great if this could be fixed!
              Deyan Hadzhiev
              Developer
              chaos.com
