I always work in cpu rendering. But I ran into a problem I could not fix.
I need to render a specific fabric with fine dots. But this causes moire effects in cpu mode.
I tried all anti alias options and many other things. But could not fix it.
When I tried it in GPU rendering it does look good. (although lighting looks different. I think it has to do with object properties tag on some objects that doesn't seem to be supported).
Can you make the mapping in CPU mode the same as the mapping in GPU mode?
