Seems to be working fine on our end, can you try to open the Console log and check for any errors printed? Also, what if you install back another build, does it behave as expected then?
I had that problem too.
See: https://forums.chaosgroup.com/forum/...-preview-stuck
It was fixed after going to Settings -> Material -> Set Material Preview to something else for ex. Cube. Then create a material. It should work. After doing that you can set it back to Sphere. Then close Cinema 4D and open it again.
Does it work now?
